With Positioning Assemblies there is the ability to use the visualization of the lower level components within the assembly.
The problem is figuring out if everything is published for large assemblies.
If you open up your assembly and the top icon has the check and green dot in the model view, you know it's fully loaded and available.
However, if you get this icon, the assembly is not fully loaded.
Which is great, but this includes items which don't show by default:
Skeletons - These sometimes can be shown but are hidden by default. It still changes the icon to say not all items are shown.
Bulk Items -which can't be shown
Included items - which can't be shown
As well as actual items missing a published viewable, or are not pulling the file due to errors
It makes it really difficult to find what's missing and what's not shown.
Now we have implemented publish.positioningassembly.publishchildren which helps TREMENDOUSLY, but I still am unsure how deep this checks.
We also have an open ticket on files not showing properly which doesn't help.
I'm not sure what would be the best way to implement this.
Creo Parametric has some tree filters that help identify objects with certain failures, or it can be done with the find tool.
