Currently using Creo View (7.1) I can open a sheet metal blank model (flat pattern), take a 2D section thru it, and Save the section as a 2D DXF. However, all circles and arcs are approximated (corded, see below).
Our laser cutter software will not import this type of geometry. This is trying to import into Radan (radan.com).
If this would work it would eliminate the arduous task of creating a Creo Parametric drawing, adding a view of the blank, and Save As a DXF simply to generate a laser cutter usable DXF. This would also enable the laser programmers to generate a usable DXF from any CAD tool blank that was published in Windchill.
