The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
In Creo Schematics incorrectly created the label with a circle.
In Creo Schematics incorrectly created the label with a circle. Many of Russian users are not happy with it.
Case12191748
2 Comments
BillF
Is everything snapped to a grid?  Looks like your circle is not centered on the grid or the radius is not a multiple of the grid.
We (librarians) start with everything based on the grid units (0.1 inch) that our designers are expected to use.  Anything that they need to position needs to work with their points on the grid.
Within a symbol, we use some smaller grids to position things properly.  Using your item as an example:  if we wanted it to be 0.5 inch circle, we would put the center of the circle and the center of the number on a 0.05 inch grid so that the ends of the 0.25" radius (that they will place a line up to) will be on the 0.1" grid.
There have been a few things where matching points up inside of a component has needed down to a 0.001 grid but the designer is never expected to place anything to those points.
It would have helped if you had shown your grid.
PTCModerator
Emeritus
Status changed to: Under Consideration
