Layer depending from attribute for Creo Schematics
The idea is to assign a layer to an artifact according to an attribute or parameter
The possibility to assign multiple layers to an artifact will also be appreciated
The aim is to is to have a 150% design from which it is ppossible to achieve a 100% design when the right options are selected.
Determine the active artifact's layer(s) from a dialog box or from a check box should be also very heplpul
3 Comments
JimBarrettSmith
olivierlp
Community Manager
Status changed to: Archived
Alex_Y
Status changed to: Under Consideration
