I want make axis or coordinate anywhere I want.
For example (0, 0, 0), when I open the file, I don't know where is start point and axis.
As you know the viewing data is came from CATIA data.
The data should have start axis and point.
Creoview menu "filter" show the all of the axis in the data, but this is so complex to see and inconvience.
This inconvience maybe solved by the function.
so please consider it as thing necessary to make axis or coordinate anywhere.
