Make possible the insertion of pdf, video and hyperlink into animation/sequence of Creo Illustrate
It would be very useful the possibility of adding pdf documents, external videos or hyperlinks into animations and sequences of Creo Illustrate.
2 Comments
Wes_Tomer
I agree that it would be useful -- especially when using a sequence for AR self-guided training via the HoloLens or iOS. The addition of an arbitrary number of parameters, to each sequence, would allow for "augmenting" the experience. The parameters would be defined at the Figure level, and then each step in the sequence would have an instance of that parameter. For instance, if it were a text box -- you could then add text for each specific step. Or if it were one or more photos, you could add photos associated with each sequence step.
These parameters would later be extracted & used in Vuforia Studio, and tied to specific widgets.
olivierlp
Community Manager
Status changed to: Archived
