Make projection measurements easier in Creo View
Currently the only way to create a projection measurement in Creo View in a vector that is not aligned with the default CYS is to load a MCAD license, create a CYS, take a measurement, select projection and select the created CYS.
I would propose that instead of creating a CYS the user be allowed to pick a surface or edge through which to project a measurement similar to the way that Creo Parametric works.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
