CreoView options has materials definitions. It can not use CreoPro materials!?? it is expecting .xml files. It should be able to share materials library from creoPro. or translate .mat files to .xml files.
Agreed! All Creo Apps should be identical. So Maybe Creo Parametric should be using materials as xml files? Either way they should be the same across the whole App Sturcture. Including Creo Simulate.
