Mesure Length in Creo Illustrate
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Reseller in France
2. What product and version are you currently running?
Creo Illustrate 9.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
See the picture. I want to mesure a length not only a distance
4. What is the use case for your organization?
Get the same behavior than Creo View
5. What business value would your suggestion represent for your organization?
Move to Creo Illustrate.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @AlexandreMG for publishing your idea. However, you give very little info. You may simply add a comment to your idea with more details and context to better document your idea, Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
Here are a few examples of well documented ideas:
Option to Import STEP file as Inseparable Assembly... - PTC Community
Improve/fix the sheetmetal mirror feature - PTC Community
Enable object update for multiple workspaces - PTC Community
Merge occurrences in Compare to Part Structure too... - PTC Community
Using "Home" and "End" keys in programming block - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
AlexandreMG
Hello, in Creo View you have different measurements possible :
In Creo Illustrate, you have only Distance, Diameter and Angle.
The idea is to get the same behavior in Creo Illustrate than in Creo View. I want the Summary, Length and Area in Creo Illustrate
olivierlp
Community Manager
Thank you @AlexandreMG for your clarifications. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
