The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Permanent Watermarking in View
Would like the ability of Creo View to permanently watermark the PVZ viewables.  This can either be embedding the current displayed watermark when the File -> Save As function is executed in the client or the ability to define a permanent watermark that is separate from the other watermarks (e.g. Copyright or Proprietary, ITAR notices)
Current functionality allows for watermarking the display in the client.  When a PVZ is loaded it will show the appropriate watermark that is stored on the server side or client side preference.  If a user then saves the PVZ to the hard drive and opens in a stand-a-lone client, the watermark will not be shown.
Use Case:
User wants to save a PVZ to the hard drive to email to a customer or supplier.  Once that PVZ is opened outside of the Windchill environment want the watermark to persist.
2 Comments
ptc-4547054
1-Newbie
Hi, Eric. I am facing the same problem! I am very frustrated about watermarking with Creo View. I thought the users couldn´t disable the markers but it´s not true. And worst I have to set each Creo View asset up to enable watermaking at printing.
PTCModerator
Emeritus
Status changed to: Archived
