Sir,
I am using creo illustrate 4.2. I have done few projects in illustrate and try to open in "vuforia".
but I found that there was some options that I cant see in "vuforia'.
the options are as follow.
1. note
2.cutting section
3.view(using camera to make some view)
4.the zoom IN/OUT function
5.images or pictures.
so do I have to make some setting in both the software. or the function has some limitation for use? or maybe in next update we can use them?
please kindly help me to solve this problems as i needed those for my work..
please find the attachment which i have attached.
Thank you!!!
