The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Remove / Delete additional viewables from active session
When adding a viewable to an active session in Creo View there is no way to then remove / delete that viewable without closing Creo View.
When production planning we may open a number of workpacks from Windchill to build a temporary visulation. We will sometimes append 5 or more viewables to a single session of Creo View as they are all assembled using a default CSY. These viewables can be quite large with many thousands or parts.
We do use Creo View MCAD which provides some powerfull capabilities although this simple function using Windchill cached viewables does not exist.
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
