In MPMLink Process Plans the part allocation sequence can be defined by operations. This part allocation sequence is the order in which parts are consumed at operation level and can be animated in the process plan.
This part allocation sequence could be reused in Creo Illustrate to automatically create animated work instructions. Currently the allocation sequence information is not available in Creo Illustrate.
