Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Can we add to the idea by allowing Shift + arrow to pan. Additionally if you pressed ctrl + up arrow it would zoom in, and ctrl + down it would zoom out.
