Select From Parents-button in Creo View (as in Creo Parametric)
When working with very large machines (150,000 parts), I find it efficient to open a dynamic viewable of a machine from Windchill into Creo View, and only open a more or less "empty' SimpRep of the machine in Creo Parametric. Then, I find the (sub-sub-sub-) assy in Creo View that needs work, and I find that assy in Creo and change its Representation to Master.
Now the problem: if I click an item in Creo View, I can only determine it's pathname by scrolling the browser and finding the parent assies. Not easy when assies contain lots of subparts. In Creo, I can click a part and click Select From Parents, which shows me the full path.
Can the Select From Parents function be built into Creo View, too?
Thnks!
Jaap
2 Comments
Trebla
Hi jkramer,
You could use 'Select Parent' from Structure tab:
jkramer
9-Granite
Ahhh, nice one, didn't know this button, thnx!
