when placing a 3D symbol in an illustration, I would like to define the assembled or positionned position as a fixed position!
this option exists in PTC CREO VIEW, and if you can add it in ILLUSTRATE, that would help a lot: if (by mistake) I press the "restore all componants position", I'm able to replace the symbols again...
PTC CREO VIEW button (in french) I need in ILLUSTRATE:
