create a fiber end details setting for snap to grid.
In Schematics, the wire ends will fan out from a port into lines parallel to the main fiber from the port.  The distance between the lines can be set to match the grid.  However, if a fiber towards the outside of the fan is not parallel to the main fiber, there typical is a short parallel section between the port and the location of the line because the fan out cannot end on a grid point.
It would help if there was a setting that let you lock the end points to the nearest grid point or if there was the ability to move them to a grid point.
1 Comment
PTCModerator
Emeritus
Status changed to: Under Consideration
