for the indicated lines in setting of the render mode at Illustrate
At the Illustrate, in the case of to set the lines indicated by selected 'shade with edges' in the  render mode at Illustrate, these lines are indicated by 'bold line' and 'thin line'.
But, each lines can not be selected to indicate or not with each.
ie. If I need only visible outline, I want to remove the thin line.
So, I want to method of selecting of indicating or not for each line.
The setting of 'color' and 'weight' are not enough to make illust.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
