Gurus, same question a little more complex ...
in my installation it doesn't work. Opening #view;#model setup; #lights I
can load my grey.dlg and the copy in C:\\...\lights\default-lights.dlg too.
However, Pro/E cant open it via #file; #OpenDefaultLights , #file; #System
Library is even empty.
--> This happens, when I start in my environment (config.sup and config.pro
most from my customer)
??? Any clue, which option/parameter is responsible ???
--> If I start without any config files, Pro/E can #OpenDefaultLights
without errors, but only on demand.
What am I missing?
I remember, in former installations there was a path to the texture library,
but opening the system window from Pro/E I can't find any parameter guiding
to a graphics-library. Any clue ?
TIA Uwe
-----Ursprüngliche Nachricht-----
