Add table to all Drawing sheets
MrSteveR_3
Hey,
I have created a table with ProDrawingTableCreate, it creates the table in the current sheet.
My question is how do I create or copy the same table in all drawing sheets.
I can get the  sheet's number with ProDrawingSheetsCount and loop on it, but I don't have an idea on how to place the same table in all of it.
Thank you!
msteffke
(To:MrSteveR_3)
I prefer to create the table in Creo, store it in a file location, and then use the ProDwgtableRetrieve to insert in a drawing.   You could perhaps loop thru the sheets and insert the table in every sheet this way?
msteffke
(To:MrSteveR_3)
FV
(To:msteffke)
or create, save with ProDwgtableSave(..) and retrieve with ProDwgtableRetrieve(..), remove created table file if needs to be to keep things clean.
