Hi Everyone,
I am working on a Creo Parametric 9.0.6.0 plugin using the VB API in C# in Visual Studio and have successfully created an application that interacts with Creo when it is running in the background. I can retrieve the active session and perform operations using the API.
Now, I want to add a custom button to the Creo Ribbon panel and link it to my C# code so that it executes a function when clicked. I came across a similar discussion in the community and wanted to confirm whether this can be achieved using the VB API in C#.
I would really appreciate any pointers, references, or guidance on implementing this. Any insights from those who have done similar work would be greatly helpful.
Thank you!
Hi @HS_12890270
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
