Hi All,
I'm facing an issue while creating drawing notes in creo parametric 2.0 from model server as explained below.
When I enter the note in drawing having character x², model server is some how converting the square symbol to x² .
Did anyone one face same issue & got the solution ?
I appreciate your time 🙂
Could be font related.
Are you using the superscript on/off option in your text string for the '2'?
Hi Ben,
Could you please explain me lil bit about, how do I use superscript on/off option ?
Thanks of your reply.
These 2 articles explain how to do it.
https://www.ptc.com/en/support/article?n=CS38901
https://www.ptc.com/en/support/article?n=CS174321
Hi Ben, Thank you so much for your help.
I'll try these steps.
Hope it works 🙂
Thanks again
I know it's kind of easy to use the superscript stuff, I've used it before, too. But I really dislike the line spacing effect it causes, where the white space above/below the line is expanded to accommodate the text. I've found that it works better for me to pop open a Word file, insert the symbol I want, like ² or ³, and they copy/paste the character into my text in Creo. Something I found out via a "I wonder if this will work" type of "experiment". It will look weird if the text editor is invoked to modify a note or whatever, but as long as it looks okay in my notes or table entries, I'm fine with that.
