Adding buttons to the ribbon with custom functions
ilyachaban
I've been using VB API for a couple of weeks now and now i want to add a button to the ribbon. But I can't even start an application in CREO.
My code looks like this:
Imports pfcls
Module Module1
    Public asynconn As New CCpfcAsyncConnection
    Public conn As IpfcAsyncConnection
    Public session As IpfcBaseSession
    Sub Main()
        user_initialize()
        user_terminate()
    End Sub
    Sub user_initialize()
        conn = asynconn.Connect("", "", ".", 1)
        session = conn.Session
    End Sub
    Sub user_terminate()
        conn.Disconnect(5)
    End Sub
End Module
My protk.dat file:
NAME test
EXEC_FILE D:\Users\Creo_7\Test_Button.dll
TEXT_DIR D:\Users\Creo_7
STARTUP dll
delay_start FALSE
allow_stop TRUE
REVISION 2001
END
 config.pro:
protkdat D:\Users\Creo_7\protk.dat
What is a minimum requirements for creo VB application to run inside of CREO and how than can I add button on the ribbon?
Errors that I'm getting
Take a look here:
VladimirN, thank you for those materials bu the didn't help me.
Is there anything like this for VB API. I've found it in user guide for TOOLKIT.
I'm able to start and use scripts that I have for now by running them in visual studio but I can't register application in creo.
Some solutions for this error:
All those articles are for TOOLKIT but I'm using VB API.
