Adding geometric tolerance shows the old one used
Siege_engineer
Hello All,
I have this situation where I create a drawing and I add a complicated geometric tolerance with text and symbols etc, which is fine and required for the design.
But when I want to add a new geometric tolerance it shows the complicated one. Meaning I have to delete all the text, symbols etc. I think Creo remembers the previous one. Is there a way that I could get a blank slate every time when I add a new geometric tolerance?
Best regards,
Vincent
Creo 4.0 btw.
chance you could use this as a hack to workaround
https://www.ptc.com/en/support/article/CS301775
CREO 7.0.5.0 and 8 added a setting for this option... sadly that does not help you or me(7.0.3).
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/index.html#page/whats_new_pma/drawing-preserve_properties_gtol.html
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/whats_new_pma/drawing-preserve_properties_gtol.html
I would make a mapkey that makes a clean gtol if the first workaround does not work.
