c9521b1c68within this app im calling a class from the swingX libraries (JXFrame). c9521b1c68My problem is now, that proE doesnt start the app if only the swingX.jar is located within the ./apps/jlinkapp/build folder. But as soon as I extract the "org" folder from the jar and put it directly into the build folder everything works fine. Is there a way to tell jlink in which .jars to look? Regards
hi
have you found solution?
I want to use org.apache.poi.* api to manage MS Office files
