BOM File Location
jflatt
8-Gravel
BOM File Location
I can't imagine I am the first one to run in to this issue, but I have not been able to find any answers on here yet. My company uses Creo elements/pro 5.0. The problem I am having is in trying to produce a BOM for an assembly that can be imported into Excel or some other format. I have found the feature that can do this, but there doesn't seem to be any way of directing it. Here is what I currently do to produce a complete BOM for an assembly:
-->Info-->Bill of Materials
Select Top Level (default)
Select OK
Perform manual search of C:\ to find assembly.bom.1 in order to figure out what random location creo decided to write the file to this time.
My question is, is there any way to specify a directory for the assembly.bom.1 file? Or even better, can I have it simply write to the working directory where the assembly.asm.1 file is actually stored?
dgschaefer
(To:jflatt)
I've just tested it and it does save into your working directory, regardless of where the assy came from. To be clear - if your assembly came from another folder other than your working directory, it'll still save to your working directory.
Search the knowledge base and you'll find documentation on customizing the template for the info > BOM feature.
Also, you can filter all the non-component info (placement folder, features, etc) out of the model tree, add columns for the parameters that you need, expand all and save it out as a text file with good results.
LinkedIn
TomU
(To:jflatt)
I think the more common approach is to create a report (or drawing) of the assembly with a repeat region configured to show the information you care about on your BOM, and then export this table directly for use in Excel. This provides much more control over what information is displayed, how it's formatted, etc.
Specific to your question above, the report should be written to your current working directory. If you haven't changed it, this should be the same as your start-in directory.
dgschaefer
(To:jflatt)
LinkedIn
Greetings. I am just learning Creo 3.0 and am trying to generate a BOM from an assembly. However, at this point the generated BOM file is empty (0 kb). I would appreciate your help. I am selecting a drawing view before clicking on Bill of Materials button.
Tom T.
StephenW
(To:jmorris)
Try opening the assembly and then going to Tools - Bill of Materials.
