We went from 4.0 to 7.0. Now the imbedded browser window graphics is too large for the window it is in. I changed the % size of the main window display in Options but this had no affect on the relative size of the graphics within the window. I have tried other Options settings and not found anything to help. It is the same regardless of the monitor size and/or display resolution as well.
Checkout the pic below. This is nearly useless!
1.) Which embedded browser are you using? You can check by looking at the windows_browser_type config option inside Creo.
2.) What is your screen resolution?
A similar issue - "Creo Parametric 4.0 embedded chromium_browser display issue with Windows 10 scale larger than 100%": https://community.ptc.com/t5/System-Administration/Creo-Parametric-4-0-embedded-chromium-browser-display-issue-with/td-p/493194
There are some known default zoom issues with the Chrome embedded browser in certain builds of Creo. That why I wanted to know what browser first...
