CREOSON: How to get the Grid-Reference of a dimension in .drw ?
Kittychen
How to get the Grid-Reference of a dimension? I tried to read a dimension by CREOSON
c.dimension_list_detail(name='D14')
and the response is :
[{'dwg_dim': False,
  'dim_type': 'linear',
  'name': 'd14',
  'sheet': 0,
  'value': 30.0,
  'encoded': False,
  'text': ['{0:@D}\n']}]
 No grid-reference info. So what's the correct way?
6 REPLIES 6
please explain the term “Grid Reference”.
Martin Hanák
Kittychen
(To:MartinHanak)
We can see that A3 is the grid-reference of the dimension. How to get this information programmatically  through CREOSON ?
so you have grid defined in your format file, do you ?
I hope @DavidBigelow knows an answer.
Martin Hanák
Kittychen
(To:MartinHanak)
Hi Martin,
Thank you so much.
Your question has actually answered me with the solution.
Best regards
Well done @Kittychen!
If you have an API possibility next to Creoson you could also ask for the Grid:
TK - ProDrawingPosToLocgrid
OTK:
JLink - I think there is no implementation for this ... but I'm not sure (haven't found it for Creo 3.0).
Else you need to know the set Format on the specified sheet to calculate the right grid position.
Only thing that can go wrong (in theory) is that the frame had changed in the meantime. You can not ask for the used drawing frame version.
Br,
Eike
