Is there anyway to enable the clock parameter in Creo 10?
what do you mean with clock parameter ?
config.pro option CLOCK yes|no was removed.
The config option you mentioned is what I meant. I noticed it wasn't in config.cdb so was hoping there was some way to enable, perhaps a hidden config option. Seems odd to remove that. It was fairly useful.
A quick check of all the config options shows that CLOCK is completely gone. It is not made a hidden option, as is often done for "obsolete" entries.
Looks like the future will have lots of spinning clocks in it.
