Clustering Mirror Image Parts using Automation
Newbie
Using the Automation function through .DAT files I can only cluster a LH
version of a part in sheet metal manufacturing. ProE will custer two LH
parts together but the RH Mirrored image will only place one part per
sheet. I have submited a SPR to PTC... the only response back was to
change the Angle setting to 1 Deg. This results in the Rh version
clustering two per sheet but now ProE only place one LH version per sheet.
Has anyone else experienced this problem????? The parts are not
complicated geometry... ProE should be able to cluster both mirrored
images the same Way!!!!!!
