Hello
We are trying to set coincident constraint between surface of two parts using Toolkit. Confusion is related to use of PRO_ASM_MATE and PRO_ASM_ALIGN as constraint type. I suppose it is related to vector direction of two surfaces to be constrained. Can anyone suggest on this?
Regards
Ketan
Those are the equivalent of the Mate and Align constraints.
Mate = (Normal) Vectors are opposite
Align = (Normal) Vectors are the same
