Connecting Cero parametric 10 (Toolkit) and Visual studio
PH_10785300
I'm experiencing significant issues connecting Creo Parametric with Visual Studio. Currently, I'm referring to the "Creo Object Toolkit C++ Release Notes" for guidance, but I'm encountering numerous errors. Could you provide a step-by-step guide on how to properly connect Creo and Visual Studio?
Thank you.
Ben_C
(To:PH_10785300)
Those errors suggest that in your project properties you have not included the directories where those header files exist , e.g.:
The paths you would need to include are:
<Creo install loaction> \Common Files\otk\otk_cpp\include\
<Creo install loaction> \Common Files\otk\otk_cpp\otk_examples\includes\
7 REPLIES 7
Ben_C
(To:PH_10785300)
See section "Debugging Creo TOOLKIT Applications" in "Creo Toolkit User's Guide" aka tkuse.pdf
PH_10785300
(To:Ben_C)
Like These types of errors i am getting,
Ben_C
(To:PH_10785300)
PH_10785300
(To:Ben_C)
After including Directory i a getting these errors. please help to solve this
Ben_C
(To:PH_10785300)
You cannot launch the compiled application directly from Visual Studio, you need to launch Creo with your application loaded and then "Attached to Process" Xtop.exe from within VS.
Look into <Creo inst>\Common Files\protoolkit\Creo_Toolkit_GSG.pdf for initial information and Chapter 94 in tkuse.pdf for a more in depth guide.
PH_10785300
(To:Ben_C)
Parametric is open, code having 0 errors, but still i am getting error like,
Unable start the program "C:\Program Files\PTC\Creo 10.0.0.0\Common Files\otk\otk_cpp\x86e_win64\obj\otk_install\otk_install\otk_install\x64\Debug\otk_install.log
the system cannot find the file specified
PH_10785300
(To:Ben_C)
Also i am getting same error like before,
after adding the path of the directories.
and in empty screen i am getting error like
please help me to solve this
