I just tried to install Creo2 M100 to x:\ptc and it went to the default c:\Program Files\PTC folder instead. I even did it twice to be sure I had it enetered properly. Has anyome else seen this behavior?
Ben,
After defining the installation location as X:\ptc, hit enter on keyboard to incorporate the change location.
Possibly this should help.
Ben,
That worked.
Got the answer and already did the install from the Exploder before this answer showed up from the Community.
