How to create the component interface using Creo Toolkit in part model?
Found the solution for it. Below is element tree structure for component interface
static ElemTreeData tree[] = { {0, PRO_E_FEATURE_TREE, {(ProValueDataType)-1}}, {1, PRO_E_FEATURE_TYPE, {PRO_VALUE_TYPE_INT, {PRO_FEAT_COMP_INTERFACE}}}, {1, PRO_E_COMP_INTERFACE_NAME, {PRO_VALUE_TYPE_WSTRING}}, {1, PRO_E_COMPONENT_INTERFACE_SETS, {(ProValueDataType)-1}}, {1, PRO_E_COMP_INTERFACE_CONSTRAINTS, {(ProValueDataType)-1}}, {2, PRO_E_COMP_INTERFACE_CONSTRAINT, {(ProValueDataType)-1}}, {3, PRO_E_COMP_INTERFACE_CONSTR_TYPE, {PRO_VALUE_TYPE_INT, {4}}}, {3, PRO_E_COMP_INTERFACE_CONSTR_REF, {PRO_VALUE_TYPE_SELECTION}}, {3, PRO_E_COMP_INTERFACE_CONSTR_REF_OFFSET, {PRO_VALUE_TYPE_DOUBLE, {0.0}}}, {3, PRO_E_COMP_INTERFACE_CONSTR_RULE, {PRO_VALUE_TYPE_INT, {0}}}, {3, PRO_E_COMP_INTERFACE_CONSTR_SET_ID, {PRO_VALUE_TYPE_INT, {-1}}}, {3, PRO_E_COMP_INTERFACE_CONSTR_ATTR, {PRO_VALUE_TYPE_INT, {0}}}, {1, PRO_E_COMP_INTERFACE_RULE, {(ProValueDataType)-1}}, {1, PRO_E_COMP_INTERFACE_RECEIVE_TYPE, {PRO_VALUE_TYPE_INT, {0}}}, {1, PRO_E_COMP_INTERFACE_TYPE, {PRO_VALUE_TYPE_INT, {5200}}}, {1, PRO_E_COMP_INTERFACE_DEFAULT, {PRO_VALUE_TYPE_INT, {0}}}, {1, PRO_E_COMP_INTERFACE_DESCRIPTION, {PRO_VALUE_TYPE_WSTRING}} };
