I am trying to create a solid model with extrusion. I need to create a sketch first and then extrude. Is it possible using VB Api alone?
If yes, what are the objects I need to use? Is there a object for creating sketches?
Article - "How to create and redefine features through Creo Parametric VB API?": https://www.ptc.com/en/support/article/CS126029
