Creating model instances using pro program
Rohan7
Hello everyone! I am trying to create instances of a model but when I provide input and relation and save the .lst file I can't see the drop-down menu which consists of enter, input parameters. I am working in Creo 5.0, a back-end compiler flashes and disappears. When I click show design, a prompt says do you want to overwrite existing? All the model relations are erased from the .lst file
How can I fix this problem? Back end compiler just flashes and disappears. How to keep this back end compiler running in order to create dialog box using pro program?
Regards
Rohan
Mahesh_Sharma
22-Sapphire I
(To:Rohan7)
@Rohan7
Try adding bin folder location for Creo 5.0 installation in PATH variable (System Environment variable).
Check for any error or warning in message area.
Can you create a quick video to display the issue?
Yeah will do...
The problem is due to the command line editor (cmd.exe)...
Hello! This video is regarding the problem I had mentioned before...
