This is what I see posted on PTC's website:
I know that but why the change in numbering like that. Is there a reason?
I think I saw someplace that it was because of Creo+. Creo+12.0 is available now. Creo+ gets quarterly updates. By next spring when Creo 12 for on-site is released, Creo+ will be at 12.4.0, so that will give the on-site and cloud versions the same version number.
That make sense…
Hi @rstreet ,
It appears that this Post answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Thanks for the info. I search PTC support and did not find this article.
