Creo 3.0 JLink Issue
dbhensdadia
HI,
I have java application which is currently working in Creo 2.0. Yesterday we had installed Creo 3.0 and checked the application but it is throwing the below error:
Can not read params from db java.lang.SecurityException: Prohibited package name: java.util
I am using the below java version:
C:\>java -version
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 1.8.0_151-b12)
Java HotSpot(TM) Client VM (build 25.151-b12, mixed mode, sharing)
Dhimant
6 REPLIES 6
Hello @dbhensdadia
Check installation of default JRE in Creo 2 and Creo 3
JRE is installed at <Load point>\$PRO_MACHINE_TYPE\obj\JRE\
Check in config.pro option jlink_java_command. If you have this option, than Creo using external JRE. Try to comment this option.
This error is gone now I am getting the error while registering the jlink application.
Actually I have the existing jar file which is running fine without any error.
When I tried to rebuild the code inside the net beans and then if I am trying to use the update jar files I am getting the error: Startup of application "xxxx" failed.
I don't know why because the other old binary is running fine but updated one not.
Can you suggest me why it is so?
Dhimant
@dbhensdadia When you rebuild the code inside the net beans, ensure in NetBeans setting that you use JDK the same or lower then JRE. Look at next message in this theme.
just FYI. Last week I created J-Link application for Creo 4.0. During my work I got error: Startup of application "xxxx" failed. The root of the problem was 32-bit Java 1.8.161 installation. When I installed 64-bit Java 1.8.161 the error was gone.
Note: I applied following command, too
set PRO_JAVA_COMMAND=C:\PROGRA~1\Java\jre1.8.0_161\bin\java.exe
Martin Hanák
will creo work with java 9?
Hi @rmcboaty
Creo 3:
JDK 1.7.0_25
JRE 1.7.0_25 (on media)
JRE 1.8.0_40
Creo 4:
JDK 1.8
JRE 1.8
