I have the Creo 3.0 M060 help files locally for both parametric and simluate, which I wanted for users who might be traveling and using borrowed licenses. This must be an issue with Creo 3 and IE10 with annoying activex control issues or just security issue, which I can't change for the users, so I guess I can live with that. But, I think I must have missed something, because I cannot get learning connector to work. I click the tab and then nothing happens, it won't expand or anything and I get no error message of any kind.
We had an issue with the learning connector icon not working in Creo 2 m120. It took forever to figure out the issue. Once we added this "ENV=PRO_LANG=C" to our psf's the learning connector icon worked. I don't know if it will have the same effect for you but you could give it a try.
