For most advanced Creo develop team and users, trend to make design or process easier and smarter, by adopting a lot parameters and relations in Creo templates and UDFs. This does improve work efficiency and enhance quality control, particularly for small or medium complexity of design or process job. But if overusing relations in UDFs and templates in big complexity of Creo design job, Creo performance becomes bottleneck while any editing action causes regeneration.
I use a medium complexity of Creo MFG model, to demonstrate the comparison of Creo regeneration performance between fully relations loaded and no relations loaded.
/* PLATE_MID_REF, HALF THICKNESS
D2546=DISTANCE:FID_THICKNESS/2
/* PROB LOCATION OP1
D2570=WRK_WIDTH:162/2
D2566=WRK_LENGTH:162/2
/* PROB LOCATION OP2
D2583=WRK_LENGTH:162/2
D2584=WRK_WIDTH:162/2
FC = 1
SC = 1
IF MATERIAL=="H13_S"
FEED = FC*FEED_H13_S
SPEED = SC*SPEED_H13_S
ENDIF
IF MATERIAL=="H13_H"
FEED = FC*FEED_H13_H
SPEED = SC*SPEED_H13_H
ENDIF
Using a medium complexity of MFG model, move all non-NC features to the location exactly before the feature of Operation. This task should be completed for both scenarios of relations fully loaded and no relations loaded for the same MFG model.
I wrote a ToolKit application to run this task inside Creo, it will do this automatically and log the processing information and time consumption.
Moving the Reference features to top of Operation OP010......
Start Time: 2018-12-08 13:46:56......
Features: 16308;16309;16664;16665;16666;16667;16669;16671;16673;16675;16676; are moved to top.
Features: 16726;16727;16728;16729;16731;16733;16735;16737;16738; are moved to top.
Features: 16797; are moved to top.
Features: 16806; are moved to top.
Features: 16910;16896;16897;16899;16900; are moved to top.
Features: 17287;17290;17293;17294;17298;17301;17302; are moved to top.
Features: 24642;24645;24648; are moved to top.
Features: 24839;24840;24842;24844;24848;24849;24853;24854;24858;24861;24862;24864;24865;24866; are moved to top.
Features: 38443; are moved to top.
Features: 38464;49629;49632;49633;49637;49638;49640;49641; are moved to top.
Features: 49743;49744;49745;49747;49749; are moved to top.
Moving NON-NC features is done!
Moving Reference Features End At: 2018-12-08 13:58:46
Total Time For Operation is: 0 days, 00 hours,11 minutes,50 seconds.
Removed Relations for All NC Sequences in Operation OP010 ...
Removed Relations for All NC Sequences in Operation OP020 ...
Removed Relations for All NC Sequences in Operation OP030_SIDE_WORK ...
Start Time: 2018-12-08 14:21:41......
Moving Reference Features End At: 2018-12-08 14:22:28
Total Time For Operation is: 0 days, 00 hours,00 minutes,47 seconds.
Apparently, heavily using relations in Creo model, dramatically slow down Creo regeneration performance. From my testing result, it caused almost 10 times slower. This number may changes depending complexity of Creo model and density of relations used.
Since relations is critical for existing UDFs in most case, and relations contains a lot prebuilt MFG processing knowledge, it does save great deal of human efforts on daily work.
So the conclusion is to improve Creo regeneration performance, remove all relations from all features, and bring them back after all editing tasks( including redefining, reordering). This will save you huge amount of time.
