Hi Everyone,
I am writing a program that allows users to trigger events in creo from an external application. I am having difficulty, however, getting a pointer to the Creo session to execute the actions.
For example, after a user clicks on the button to create a new part, I am able to get a pointer to the session object using pfcGetProESession(), but when I try to call OpenFile() I get an AccessViolation error.
When I run these same commands after clicking on a button from Creo, however, it works.
Is there a command I need to call to allow me to use the Creo session when triggered by an outside event?
Thanks for your help,
Dan
Not really an answer, but I was able to get around this problem by using "Asyncronous Mode."
Hi @dstaves
Some times the access violation error occurs in asynchronous mode due to the platform configuration changes.
Make sure your asynchronous application and the creo having same version (x64bit or x86bit)
