Creo paramatric 4.0 otk_java_free help needed!!!
Ragnarok8979
6-Contributor
can somebody guide me how to use otk_java_free . and how to set it up?
i have code written but dont know how to use that.
your help will really appriciated.
Depending on what you are trying to do with it.... It might be worth a look at :
CREOSON.com
It is written with JLINK and is probably a bit easier to use (again depending on what you are trying to do).
If you are a Python user - this may make it even easier:
https://creopyson.readthedocs.io/en/latest/
Dave
sjuraj
(To:Ragnarok8979)
You need to see manual located in
<creo_install_folder>Common 20Files/otk_java_doc/otk_javaug.pdf
There is all nicely explained
