Creoson how to display annotations or dimensions in generated drawing
CB_14084871
2-Explorer
I've been trying to use the creoson libraries to pass parameters to a model and generate a drawing from javascript ... but the dimensions in model could not be displayed in the generated drawing.. when i try to do the following,
dimObj = new creo.DimensionObj();
dimObj.name = "d0";
dimObj.showFlag = true;
respdata = await dimObj.list({file:"mydrawing.drw", name:"*"});
it returns a blank array
when i try
dimObj.show({file:"mydrawing.drw", name:"d0", show: true});
to show an existing dimension from the model from which i generated the drawing, it reports, the dimension does not exist.. and ofcourse the dimensions are visible in creo when i manually use the "show annotations" toolbar button.. sadly, theres no show annotations interface function in creoson dimension module... any suggestions / help is appreciated
5 REPLIES 5
Hi @CB_14084871
Thank you for your post.
Best regards,
Catalina
PTC Community Moderator
PTC
Maybe not the cleanest and simple solution, but you could play a mapkey or trail file to do these actions.
=> Show annotations
=> Search for that specific dimension
=> Accept annotation placement
I have used the same method in the past and this worked for me.
Pretty sure that this only works for .prt/.asm -- not .drw files.   If you want to show the dimension on the drawing - might consider a mapkey to find and show the dimension, but showing dimensions on drawings is typically view dependent.
Automating drawings is a different head-space.  They are very limited - typically using drawing templates is best for new automations, or placing views and showing the feature dimensions by default - knowing they will go away if the model feature is suppressed.  Either is a more preferred approach for drawings vs tying to show specific dimensions by view using a mapkey or trail file.
hope this helps.
Dave
No I use it for drawings.
It will show the dimesions on the first view where it is possible to show the dimension.
With this method you do not have a lot of controll on that.
I use it to automatically generate a drawing and show all the dimensions with tolerances.
(I analyse the ProProgram to find these dimension.)
The user will still need to clean/move the dimensions.
Hi @CB_14084871,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC
