Custom Dimension Text
Aravind98
Hi Guys
can we add custom symbol in Dimension Text?
if any one knows pls let me know.
regards
Aravind
Vladimir,
the question is related to Creo Toolkit...
Martin Hanák
Hello @Aravind98
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution. Or if you found a solution yourselves, please document it in your topic and mark it as accepted solution. It will surely help other users who have similar questions.
Community Moderation Team.
RPN
(To:Aravind98)
You must enter the escape sequence in the text.
First do it manually, create a note with the symbol, next get the note via toolkit and check the note text.
