Deaktivate Toolkit license entries without softwareinstallation - virtual machine were deleted
ctilemann
a long time ago ...
we installed 3 virtual machines with the named user authentication.
The vm were deleted without deactivation the named user license
Is it possible that the support do that?
you published your question at user forum/community. PTC Support is available at support.ptc.com
I do not understand what you mean, when you speak about "named user license". Is it ProE/Creo license ?
I have always seen:
  1. Pro/Toolkit license as part of ProE/Creo license
  2. ProE/Creo license as node-locked or floating
MH
Martin Hanák
I will move this to the Creo Community
Hello
I have 3 licenses for test-nodes aktivated.
Now we want to aktivate the production machine.
So how could i delete this and aktivate the new one?
I guess your question does not belong to Creo area. I think you are using MKS Toolkit 9.5. If I am right then the best solution is contacting PTC Support -or- PTC VAR who sells licenses to your company.
MH
Martin Hanák
