Hi All,
I'm currently using Creo 10 and am interested in improving how I detail standard holes, In the past I have put a lot of work into the .hol files and had some success with making this work, but I have a problem where the parameters used by the hol files do not pull through the tolerance for that size,
I think I have to move to building ISO style hole callouts using &d dimension callouts in a note or lead dimension. Does anyone have experience or access to a toolkit module that can help tie up the &d values for a hole, the info > feature dimensions seems to do this, but it doesn't tie up to any description or repeatable convention I can see, and there's no description link like what the Feature Element Data or "local parameters" table provide for the hole sizes, but not dim ref's.
Many thanks in advance
Dave.
Hi @dmccandless
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
