Dimension Visit to find a dimension by name
Manjunath
Hi All,
I use ProSolidDimensionVisit(), to get a dimension names "Test" from a part. And I need to add flexibility in Assembly. I use the following code, in this case it takes only first dimension. Kindly throw some light how to find the dimension with name.
ProError dim_visit(ProDimension* dimension,ProError status,ProAppData data)
ProName d_name;
char dim_name[PRO_NAME_SIZE];
status = ProModelitemNameGet(dimension,d_name);
ProWstringToString(dim_name,d_name);
if (strcmp(dim_name,"Test") == 0)
return status;
return PRO_TK_CONTINUE;
GabrielZaha
(To:Manjunath)
There are two things that you need to pay attention.
First: to get the dimension name you need to use ProDimensionSymbolGet function.
Second is the return of the visiting function. Anything other than PRO_TK_NO_ERROR will make the ProSolidDimensionVisit function to stop. In the example you posted the return is set to PRO_TK_CONTINUE wich will make the visiting stop.
I guess what you are looking for is something like this:
	ProName d_name;
	status = ProDimensionSymbolGet(dimension,d_name);
		//do something here
	return PRO_TK_NO_ERROR;
GabrielZaha
(To:Manjunath)
	ProName d_name;
		//do something here
Manjunath
(To:GabrielZaha)
@GabrielZaha , its working tnx for the info..
