I would like to ask You if it´s possible set the gap between leader(dimension) line and dimension text (on the picture). I tried to use dim_text_gap but it doesn´t work as we wanted. i found article that is impossible ( https://community.ptc.com/t5/3D-Part-Assembly-Design/Increase-dimension-offset-from-leader/td-p/616756 ) Just want to make sure, that still valid. Other solution we already discussed.
Thank You
Have a nice day
I think it is not possible.
Also see https://www.creosite.com/cgi-bin/find_option.cgi?srch=dim_text_gap&ver=creo1&mode=drwsetup page.
