Dynamic Editing of Cutout Features in SMARTElectrode
FlorianHammrich
In SMARTElectrode 12.0.2.0, size and position can be changed dynamically after selecting the geometry.
Application of dynamic editing
After selecting the surfaces for manufacturing, the definition of the cutout can begin using the command. The respective selected coordinate or dimension is highlighted in the object window.
When the “Dynamic Drag” button is pressed, drag elements are displayed that can be moved by holding down the left mouse button. The size and position are adjusted directly.
The cutout is created with “OK”. Already created cutouts can be redefined later in this way. This function allows a more flexible use of the cutout feature in SMARTElectrode.
Find more about the dynamic editing of Cutout Features:
Here you can find a step by step introduction:
https://www.buw-soft.de/en/2020/02/21/dynamic-editing-of-cutout-features/
Availability From version SMARTElectrode 12.0.2.0 on, the dynamic editing of the cutouts is available for all electrode assemblies.
Florian Hammrich
B&W Software GmbH
0 REPLIES 0
