*** "IpfcAssembly.AssembleByCopy" *** ask for use
This function copies existing parts in assembly and automatically assembles new copied parts.
This is the code i made. there is an error
Dim Solid As IpfcSolid
Dim Assembly As IpfcAssembly
Dim ComponentFeat As IpfcComponentFeat
Dim CreateModelDescriptor As New CCpfcModelDescriptor
Dim ModelDescriptor As IpfcModelDescriptor
'// Load model from "rod_nut.prt" file into Session
Set ModelDescriptor = CreateModelDescriptor.CreateFromFileName("rod_nut.prt")
Set Solid = session.RetrieveModel(ModelDescriptor)
Set Assembly = model
Set ComponentFeat = Assembly.AssembleByCopy("C:\PTC\WORK90\JP100.PRT", Solid, True)
the code that gives the error
please correct
e-mail : korealionkk@gmail.com
Try this one: `Set Assembly = Model`.
This is the full vba code
Public asynconn As New pfcls.CCpfcAsyncConnection
Public conn As pfcls.IpfcAsyncConnection
Public session As pfcls.IpfcBaseSession
Public model As pfcls.IpfcModel
Sub model_session()
'// Displays the name of the model in the current session
Set conn = asynconn.Connect("", "", ".", 5)
Set session = conn.session
Set model = session.CurrentModel
On Error GoTo E01
If model Is Nothing Then
Err.Raise 5001, , "▶ No models are currently active ◀"
End If
Exit Sub
E01:
MsgBox "Error Number: " & Err.Number & vbNewLine & _
"Error Description: " & Err.Description
Err.Clear
End Sub
Sub componentcopy()
'// current session connection
file_name.model_session
Dim componentFeat As IpfcComponentFeat
Set componentFeat = Assembly.AssembleByCopy("C:\PTC\WORK90\JP100.PRT", Solid, True)
'Cleanup
Set asynconn = Nothing
Set conn = Nothing
Set session = Nothing
Set model = Nothing
End Sub
. The "model" variable holds information about the currently active assembler file
. Assigned "model" information to "Assembly" variable
. I am getting an error in the code above
. "C:\PTC\WORK90\JP100.PRT", I also tried typing "JP100.PRT"
. I also tried changing the file name to lower case.
. I am not a program development expert. I am making a simple program with the help of chatgtp.
The creo vba code provided by chatgtp cannot be used. But I'll give you a hint.
. mapkey cannot be configured with chatgtp ^_^
please correct
Assembly = CType(model, IpfcAssembly)
ps: some examples ..\Creo x.0.x.0\Common Files\vbapi\vbapi_examples
- This is the VB.NET program code
C:\PTC\Creo 9.0.4.0\Common Files\vbapi\vbapi_examples
- This folder contains only VB.NET code.
EXCEL VBA code examples are not provided in the PTC folder
We hope that PTC has provided many EXCEL VBA example codes and functions. No separate compilation function is required. You can connect with the database through EXCEL. General EXCEL VBA code is created by ChatGTP. Anyone can easily create an automated one with EXCEL VBA
Yes, you are correct! My mistake.
Take a look at me_Example.xls
I have a trouble to load a model using RetrieveModel. So need to open PRT manually and I'm use a method GetModelFromDescr to get a part from a session.
PS: I'm not sure that is possible to easily create an automation with ChatGPT. Need to understand the source code that you writing. Try to read "Overview of the VB API" chapter from VB API manual for better understanding.
thank you
I'll test it
We are testing whether VB.NET files in C:\PTC\Creo 9.0.4.0\Common Files\vbapi\vbapi_examples can be converted from ChatGPT to EXCEL VBA code. CREO users who are interested in EXCEL VBA, try coding with ChatGPT
